Publisher: Ubisoft
Far Cry 2 is the latest first person shooter from Ubisoft and it's one of the most hotly-anticipated games of this year. While it continues the
Far Cry franchise that Crytek started in 2004,
Far Cry 2 is built on its own in-house engine and has no association to anything Crytek has worked on or is working on now.
The game
uses DirectX 10.1 to improve anti-aliasing performance and quality. The improvements are made by reading the multisampled depth buffer in a single pass - something that was only introduced officially with DirectX 10.1. However, Ubisoft has also made the enhancements available to Nvidia hardware as well through a DirectX 10 extension.
We used the game's built-in benchmarking tool to measure performance in DirectX 9.0 mode - this provided a pretty accurate rundown of how various graphics cards perform and it shows off a lot of the game's special effects. We set every option to its maximum setting and tested at 1,680 x 1,050, 1,920 x 1,200 and 2,560 x 1,600 with various anti-aliasing settings.
Anisotropic filtering is controlled by the game's quality settings and forcing AF from the driver control panel does not have any effect on visual quality or performance.
ATI Radeon HD 4870 X2 2GB
Sapphire Radeon HD 4890 1GB Atomic
Nvidia GeForce GTX 275 896MB
ATI Radeon HD 4890 1GB
Asus Radeon HD 4890 1GB
MSI N260GTX Lightning
Nvidia GeForce GTX 285 1GB
Nvidia GeForce GTX 260-216 896MB
20
30
40
50
60
70
80
Frames Per Second
Frames Per Second
20
30
40
50
60
70
80
Frames Per Second
Frames Per Second
Frames Per Second
Frames Per Second
The Lightning did better than many cards producing a higher minimum frame rate than even a GTX 285 in some tests, a feat that is no doubt due to its massive 1,792MB of GDDR3 memory. Not many games benefit from this additional memory but
Far Cry 2 is one of them, especially when you start to up the resolution and there is many more pixels that need rendering.
